Globally disables ping protection for static routes added with ping protection for IPv4 and IPv6. Routes are up in the routing table, and ping health check monitoring is not performed.
| ipv4 | Specifies IPv4 (default). |
| ipv6 | Specifies IPv6. |
| protection | Disables route protection. |
| ping | Globally disables ping protection for static routes added with ping protection (default is enabled). |
Enabled is the default. If not specified, IPv4 is the default.
The following example disables ping protection for static routes added with ping protection for IPv4:
# disable iproute ipv4 protection ping
This command was first available in ExtremeXOS 22.1.
This command is available on all platforms with any license level as described in the Switch Engine v33.1.1 Licensing Guide document.
